I'm trying to extend the life of my Asus M2N-SLI Deluxe mobo. I do a lot of graphic design but also want to enjoy the new games that are coming out. Here are the specs of my current box:
AMD Athlon Brisbane 64 X2 5200+
8.0 DDR2 G.Skill Memory
Nvidia GeForce 9600 GSO vid card
My question is, is it worth trying to upgrade to a new quad core processor? Am I better off going with a stout dual core instead or even a 3 core? My system has been a bit laggy lately and I imagine the bottleneck is the CPU.
Am wondering if any of the AMD Phenom 2 processors would be a good choice for my 64bit system?
HTML:
[QUOTE]Summary
Operating System
MS Windows 7 Enterprise 64-bit SP1
CPU
AMD Athlon 64 X2 5200+ 37 °C
Brisbane 65nm Technology
RAM
8.0GB Dual-Channel DDR2 @ 387MHz (5-5-5-15)
Motherboard
ASUSTeK Computer INC. M2N-SLI DELUXE (Socket AM2 )
Graphics
Hanns.G HG281 @ 1920x1200
SyncMaster @ 1440x900
768MB GeForce 9600 GSO (XFX Pine Group) 48 °C
ForceWare version 267.24
Hard Drives
977GB Western Digital WDC WD10 EADS-00L5B1 SCSI Disk Device (SCSI)
78GB Western Digital WDC WD80 0JD-22LSA0 SCSI Disk Device (SCSI)
78GB Western Digital WDC WD80 0JD-75HKA1 SCSI Disk Device (SCSI)
Optical Drives
NYPUF FCLQBWX2 SCSI CdRom Device
TSSTcorp CDDVDW SH-S223F SCSI CdRom Device
Audio
SB Audigy
Operating System
Installation Date: 27 September 2010, 14:20
Serial Number: BBBBB-BBBBB-BBBBB-BBBBB-BBBBB
CPU
Cores 2
Threads 2
Name AMD Athlon 64 X2 5200+
Code Name Brisbane
Package Socket AM2 (940)
Technology 65nm
Specification AMD Athlon(tm) 64 X2 Dual Core Processor 5200+
Family F
Extended Family F
Model B
Extended Model 6B
Stepping 2
Revision BH-G2
Instructions MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64
Bus Speed 200.8 MHz
Rated Bus Speed 1004.1 MHz
Stock Core Speed 2700 MHz
Stock Bus Speed 200 MHz
Average Temperature 37 °C
Caches
L1 Data Cache Size 2 x 64 KBytes
L1 Instructions Cache Size 2 x 64 KBytes
L2 Unified Cache Size 2 x 512 KBytes
Core 0
Core Speed 2712.7 MHz
Multiplier x 13.5
Bus Speed 200.8 MHz
Temperature 32 °C
Thread 1
APIC ID 0
Core 1
Multiplier x 13.5
Bus Speed 200.8 MHz
Temperature 42 °C
Thread 1
APIC ID 1
RAM
Memory slots
Total memory slots 4
Used memory slots 4
Free memory slots 0
Memory
Type DDR2
Size 8192 MBytes
Channels # Dual
DRAM Frequency 387.3 MHz
CAS# Latency (CL) 5 clocks
RAS# to CAS# Delay (tRCD) 5 clocks
RAS# Precharge (tRP) 5 clocks
Cycle Time (tRAS) 15 clocks
Bank Cycle Time (tR?) 25 clocks
Command Rate (CR) 2T
SPD
Number Of SPD Modules 4
Slot #1
Type DDR2
Size 2048 MBytes
Manufacturer G.Skill
Max Bandwidth PC2-6400 (400 MHz)
Part Number F2-6400CL5-2GBPQ
SPD Ext. EPP
JEDEC #2
Frequency 400.0 MHz
CAS# Latency 5.0
RAS# To CAS# 5
RAS# Precharge 5
tRAS 15
tRC 24
Voltage 1.800 V
JEDEC #1
Frequency 266.7 MHz
CAS# Latency 4.0
RAS# To CAS# 4
RAS# Precharge 4
tRAS 10
tRC 16
Voltage 1.800 V
Slot #2
Type DDR2
Size 2048 MBytes
SPD Ext. EPP
JEDEC #2
Frequency 400.0 MHz
CAS# Latency 5.0
RAS# To CAS# 5
RAS# Precharge 5
tRAS 15
tRC 24
Voltage 1.800 V
JEDEC #1
Frequency 266.7 MHz
CAS# Latency 4.0
RAS# To CAS# 4
RAS# Precharge 4
tRAS 10
tRC 16
Voltage 1.800 V
Slot #3
Type DDR2
Size 2048 MBytes
SPD Ext. EPP
JEDEC #2
Frequency 400.0 MHz
CAS# Latency 5.0
RAS# To CAS# 5
RAS# Precharge 5
tRAS 15
tRC 24
Voltage 1.800 V
JEDEC #1
Frequency 266.7 MHz
CAS# Latency 4.0
RAS# To CAS# 4
RAS# Precharge 4
tRAS 10
tRC 16
Voltage 1.800 V
Slot #4
Type DDR2
Size 2048 MBytes
SPD Ext. EPP
JEDEC #2
Frequency 400.0 MHz
CAS# Latency 5.0
RAS# To CAS# 5
RAS# Precharge 5
tRAS 15
tRC 24
Voltage 1.800 V
JEDEC #1
Frequency 266.7 MHz
CAS# Latency 4.0
RAS# To CAS# 4
RAS# Precharge 4
tRAS 10
tRC 16
Voltage 1.800 V
Motherboard
Manufacturer ASUSTeK Computer INC.
Model M2N-SLI DELUXE
Version System Version
Chipset Vendor NVIDIA
Chipset Model nForce 570 SLI
Chipset Revision A2
Southbridge Vendor NVIDIA
Southbridge Model nForce 570 SLI
Southbridge Revision A3
BIOS
Brand Phoenix Technologies, LTD
Version ASUS M2N-SLI DELUXE ACPI BIOS Revision 1701
Date 10/02/2008
Graphics
Monitor
Name Hanns.G HG281 on NVIDIA GeForce 9600 GSO
Current Resolution 1920x1200 pixels
Work Resolution 1920x1170 pixels
State enabled, primary, output devices support
Monitor Width 1920
Monitor Height 1200
Monitor BPP 32 bits per pixel
Monitor Frequency 59 Hz
Device \\.\DISPLAY1\Monitor0
Name SyncMaster on NVIDIA GeForce 9600 GSO
Current Resolution 1440x900 pixels
Work Resolution 1440x900 pixels
State enabled, output devices support
Monitor Width 1440
Monitor Height 900
Monitor Frequency 60 Hz
Device \\.\DISPLAY2\Monitor0
GeForce 9600 GSO
GPU G92
Device ID 10DE-0610
Revision A3
Subvendor XFX Pine Group (1682)
Technology 65 nm
Die Size 330 nm?
Transistors 754 M
Release Date May 2008
DirectX Support 10.0
DirectX Shader Model 4.0
OpenGL Support 3.0
Bus Interface PCI Express x8
Temperature 48 °C
BIOS Version 62.92.4c.00.06
ROPs 16
Shaders 96 unified
Memory Type GDDR3
Physical Memory 768 MB
Virtual Memory 512 MB
Bus Width 192 Bit
Hard Drives
Manufacturer Western Digital
Form Factor GB/3.5-inch
Business Unit/Brand Enterprise/WD Raptor®
Interface SCSI
Capacity 977GB
Real size 1,000,204,886,016 bytes
S.M.A.R.T
S.M.A.R.T not supported
Partition 0
Partition ID Disk #2, Partition #0
Disk Letter H:
File System NTFS
Volume Serial Number F473389D
Size 932GB
Used Space 830GB (90%)
Free Space 102GB (10%)
Form Factor TB/2.5-inch
Interface SCSI
Capacity 78GB
Real size 80,026,361,856 bytes
S.M.A.R.T
Partition 0
Partition ID Disk #0, Partition #0
Disk Letter C:
File System NTFS
Volume Serial Number B0FC0F73
Size 75GB
Used Space 60GB (80%)
Free Space 15.0GB (20%)
Interface SCSI
Capacity 78GB
Real size 80,000,000,000 bytes
S.M.A.R.T
Partition 0
Partition ID Disk #1, Partition #0
Disk Letter D:
File System NTFS
Volume Serial Number 809598B9
Size 74GB
Used Space 27.4GB (37%)
Free Space 47GB (63%)[/QUOTE]
