I have unlocked my processor, i can go higher with my multiplier, but i can't go lower, will not post. I suspect it may be the bios needs flashing and updated. any suggestions? I set the multiplier at 11.5 and fsb to 133 and it posts at 1800.
If it is you should be able to set any multiplier higher or lower and boot at the speed it should for that multiplier.
Maybe some expert in the amd cpu section could tell you what bridges are not connecting right that would cause you only to be able to use a higher multiplier.
