Unfortunately most quality long lasting, performing case fans are dual ball bearing or "2 ball." This is really hard to come by with a pwm circuit, and thats half the problem for water cooling.
I've got a Rocketfish (aka Lian-Li) case and baffled the case with 2x120 intake fans at the bottom of the case and 3x120 exhaust fans at the top which push through a 3x120 swiftech radiator. Now my pump runs on medium all the time but my computer rarely is under full or extreme load. I've probed radiator air exhaust temps at 72F on my Phenom II X6.
I'd like to buy/create a pwm amp circuit that ramps the load on the 3x120 fans on the radiator exhaust based on the mobo's cpu pwm fan header. The 2 intake fans in the bottom of the case I'd like to be controlled by a thermostat circuit based on the case ambient/hdd fan temps- not an on/off but a ramp up-down similar to pwm.
Can someone point me in the right direction? It sounds like a server rack at work and it blows REALLY cold air around the room!
Thanks,
M
Thanks,
M
