- May 1, 2002
- The land of cheese.
Hard to believe but this is my first post since 2003, back when I built my first rig. Well, now I'm helping my son build his first rig and I have a question that I'm almost too embarrassed to ask because I know it has a simple answer. Anyway, he bought an Enthoo Pro ATX case. It comes with a PWM hub (something I'm not familiar with) and it has a cable that says to plug into the cpu fan header. So my stupid question is, if I plug the hub into the cpu fan header, where do I plug in the cpu fan? The cable on the fan is 4 pin and all of the connectors on the hub are 3 pin. Do I plug the cpu fan into the other 4-pin header on the motherboard, or can I plug the fan's 4-pin connector into one of the 3-pin connectors on the hub? I'm really not sure. Any help would be greatly appreciated. Thanks!
p.s. I hope this is the right thread to ask in.
