- Thread Starter
- #21
Sorry for seemingly talking to myself but here's another update (this was mean't to be a log after all).
At 3.8ghz I can't get the system 100% in prime95. I've had it run for 2 hours and then give an error. Probably fine for running apps and games though. IntelBurnTest seems a bit strange as it will pass the 10 tests sometimes but the most I've had out of it is about 11.
I've tried so many different voltage settings. If anyone could give me any ideas it would be appreciated. Also I found out that my memory has 2.2v written on it (must be the early reaper HPC memory). I've been running it at 1.8/1.9 in the past! However changing this to 2.2v made no difference.
Current settings:
CPU Ratio setting 9.0
C1E Support Enabled
Max CPUID Value Limit Disabled
Intel Virtualization Tech Disabled
CPU TM Function Enabled
Execute Disabled Bit Enabled
Intel SpeedStep Enabled
CPU Ratio Manual
FSB 422
FSB Strap to North Bridge 333mhz
Dram Frequency 1014mhz
Dram clk skew C A1 auto
Dram clk skew C A2 auto
Dram clk skew C B1 Auto
Dram clk skew C B2 Auto
Dram timing control auto (5-5-5-15-3-54-6-3)
Dram static read control Auto
Dram read training Auto
Mem. OC Charger Auto
Ai Clock Twister Auto
Ai Transaction booster Auto
CPU voltage 1.5375
CPU GTL volt ref 0/2 auto
CPU GTL volt ref 1/3 auto
CPU PLL volt 1.60
FSB Termination voltage 1.32
dram voltage 2.2
NB Voltage 1.34
NB GTL Reference auto
SB Voltage 1.1
Load-line calibration Enabled
CPU Spread Spectrum Disabled
PCIE Spread Spectrum Disabled
CPU Clock Skew auto
NB Clock Skew auto
CPU Margin Enhancement Optimized
Also I have some confusion about my memory. I see in some reviews it says timings 5-5-5-18 but it automatically uses 5-5-5-15 from SPD. Should I try 18?
Current settings:
C1E Support Enabled
CPU Ratio Manual
FSB 422
CPU voltage 1.5375
CPU PLL volt 1.60
dram voltage 2.2
NB Voltage 1.34
SB Voltage 1.1
CPU Clock Skew auto
NB Clock Skew auto
