- Mar 26, 2008
- Northern NJ
As the title states I am completely stuck. I cannot get my OC to past 3.2 no matter I do. I have a odd feeling that it's my mobo. For starters no matter how high I put the voltage (tried 1.43, 1.44, 1.48) it will never go past 1.42 idle then vdroop puts it around 1.38.
I'll be the first to say that I am not a experienced OC'er by any means and most of what I'm doing is total guess work. Having said that I was definitly expecting ~3.4 with G0 & a TRUE heatsink w. a Panaflo M1BX.
Since the voltage seems to be capped for some reason, I just playing around with random FSB's. I tried a wing and a prayer 3.6, 3.5, and 3.4. Those BSOD'ed when loading. 3.3 loads into Windows, but as soon as Prime starts it crashes within ~10 seconds.
I tried all other incraments back down to 3.2 and finally 3217.8 ran a whopping 7 minutes Prime stable!
3.2 even is Prime 8 hours stable.
Highest Temp I've yet to see at all is ~61° load so I am not worried about the temp. I'm pretty sure it seems to be the mobo or the chip.
Bios settings.
Disabled everything as per THIS GUIDE
I slowed my 800mhz ram down to 400.
Full Auto works at 3.2 (I'm sure I could lower the volts but the temps weren't that bad, I'm ok with leaving tha stable for now).
680i mobo won't show higher than 1.42 volts at all in CPU-Z.
I've tried changing all the settings manually to the following:
core to 1.46 (never goes above1.42ish idle)
fsb to 1.4
spp 1.45
memory @ 1.8 (recomended)
1.525 as the nForce MCP (Southbridge)
1.34 as the HT nForce SPP <-> MCP.
Any help would be greatly appreciated. If you think its a bad chip or mobo please don't feel bad telling me. After all 3.2 isn't bad... I was just expecting better. Especially since temps aren't a problem.
Bios settings.
fsb to 1.4
spp 1.45
