Sam Stripy
- Mar 14, 2017
Hi, I have a bit of a problem and I am not sure if what I am trying to is possible with my setup or I am just doing my settings wrong. I have an Intel Q6600 Quad Core 2.4ghz on the ASRock G41C-VS, the problem I have is I have purchased the Fury HyperX 1333mhz DDR3 8gb (2x4gb) Memory Kit which I was told by Overclockers that it 'should' be OK for my board. As far as I can see in the manual and by reading on these forums this should be possible if i increase the FSB in bios and move the jumper from pins 1-2 to 2-3 as stated in the motherboard manual if using 1333mhz DDR3? I have tried setting the CPU mhz to 333x9 and moving the jumper to pins 2-3 but the computer stats up but has nothing on screen and I have to put the old RAM back in to get anything on the screen. Can someone explain where I am going wrong here? Am I simply trying to do something that will not work or am I doing it wrong? RAM is http://www.kingston.com/dataSheets/HX313C9FK2_8.pdf and motherboard manual is http://download.asrock.com/manual/G41C-VS.pdf this is a possible combination with the Q6600 with OC right? or am I completely wrong and have the wrong sticks for this? Thanks in advance.
