Alright guys, so after an hour of BF4 beating my machine up and 5 hours of cleaning my rig out by hand, I'm ready to try and overclock my Q9550 to see what kind of performance gains might be possible with my setup. Before we get started, I have to stress - this situation isn't exactly ideal for overclocking as far as I can tell, the research I have done on the board have revealed that it's not exactly overclocking-friendly, but I believe I should be able to squeeze a bit out of it.
I've never really made a serious attempt at overclocking before, any and all assistance with the voltage calculations, multipliers and FSB etc are greatly appreciated. I'll try and detail everything I can about this weird (outdated) setup.
Motherboard - P7N Diamond (MS-7510)
CPU - Intel Core 2 Quad Q9550
RAM - DDR2 400.0 MHz Single Channel
As you can see, not exactly top of the line. Even after cleaning this system out from top to bottom, with 3 unparked cores it will idle at about 42c, can reach 56-62c under heavy load on a prime95 test. The reason the cores are currently unparked was some suggestions via DICE and the community on how to optimize performance.
The Ram isn't ideal either, and no matter how much I tried - I could just not get this board to try and run it in dual channel, so it's currently single channel. I'm hoping it isn't so slow that it will limit my options heavily.
Ideally, I'd like to attempt a 3.4GHz overclock, and if I could get that running stable either creep up to 3.6GHz or stay where I am depending on system performance. CPU Cooler isn't stock, but I don't have the specs on hand (doh, forgot to grab them while cleaning it out last night!), it does an okay job for what it is - although I was surprised to see my idle temps only fall down about 15c after cleaning the cooler out thoroughly.
I think my biggest issue will be the motherboard, it has pretty limited options in terms of overclocking - from what I have read its locked into a multiplier of 8 with Intel EIST (Speed Step Technology) off, and 8.5 with Intel EIST enabled (which it is currently to help reduce temps during idle time).
So, where should I begin with this situation? I'll try and find some good pics or the manual of my mobo so you can see what im working with under "Cell Unit" options - it isn't much, but It should be enough I think to get started. Anyone have any experience with this board and CPU? or any suggestions, questions, advice?
Thanks for reading.
Code:
Manufacturer MICRO-STAR INTERNATIONAL CO.,LTD
Model P7N Diamond (MS-7510) (CPU 1)
Version 1.0
Chipset Vendor NVIDIA
Chipset Model nForce 780i SLI SPP
Chipset Revision A2
Southbridge Vendor NVIDIA
Southbridge Model nForce 780i SLI MCP
Southbridge Revision A3
BIOS
Brand American Megatrends Inc.
Version V1.4
Date 7/30/2009
PCI Data
Slot PCI
Slot Type PCI
Slot Usage Available
Bus Width 32 bit
Slot Designation PCI1
Characteristics 3.3V, Shared, PME
Slot Number 0
Code:
Cores 4
Threads 4
Name Intel Core 2 Quad Q9550
Code Name Yorkfield
Package Socket 775 LGA
Technology 45nm
Specification Intel Core2 Quad CPU Q9550 @ 2.83GHz
Family 6
Extended Family 6
Model 7
Extended Model 17
Stepping A
Revision E0
Instructions MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, Intel 64, NX, VMX
Virtualization Supported, Enabled
Hyperthreading Not supported
Fan Speed 2782 RPM
Bus Speed 333.3 MHz
Rated Bus Speed 1333.3 MHz
Stock Core Speed 2833 MHz
Stock Bus Speed 333 MHz
Caches
L1 Data Cache Size 4 x 32 KBytes
L1 Instructions Cache Size 4 x 32 KBytes
L2 Unified Cache Size 2 x 6144 KBytes
Code:
RAM
Memory slots
Total memory slots 4
Used memory slots 4
Free memory slots 0
Memory
Type DDR2
Size 6144 MBytes
Channels # Single
DRAM Frequency 400.0 MHz
CAS# Latency (CL) 5 clocks
RAS# to CAS# Delay (tRCD) 5 clocks
RAS# Precharge (tRP) 5 clocks
Cycle Time (tRAS) 18 clocks
Bank Cycle Time (tRC) 22 clocks
Command Rate (CR) 2T
Physical Memory
Memory Usage 24 %
Total Physical 6.00 GB
Available Physical 4.51 GB
Total Virtual 12 GB
Available Virtual 10 GB
Thanks for reading.
