Q9550 & XFX780i
azace
Mesa, Arizona
Okay, so I wanted to overclock my system to around 3.6 maybe higher on stock cooling.
Here are the specs:
CPU: Q9550 @ 2.83GHz
Mobo: XFX780i
VideoCard: GTX260 Superclocked
PSU: 750W Corsair
Memory: CORSAIR XMS2 DHX 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model TWIN2X4096-6400C4DHX
Windows 7 64bit
I just tweaked the FSB up to 1500 and the CPU Core to 1.2
Ran Intel Burn with stress level on standard and times to run at 5. passed
Recommendations? Would like to reach 3.6 if possible. right now its at 3.19
redduc900
Inactive Moderator
Portland, OR
Use this template for the XFX 780i to post all of your current BIOS settings at 3.19GHz (just disregard the settings in the template, and replace w/ your own)...
Code:
Advance Chipset Features
System Clocks
** Frequency Setting **
CPU Multiplier - x9
PCIe x16_3, MHz - 120
SSP<->MCP Ref Clock, MHZ - 250.0
** HT Multiplier **
nforce SPP --> nForce MCP 4 x
nforce SPP <-- nForce MCP 4 x
** Spread Spectrun Setting **
x CPU Spread Spectrun - Disabled
x HT Spread Spectrun - Disabled
x PCIe Spread Spectrun(MCP) - Disabled
x SATA Spread Spectrun - Disabled
FSB & Memory Config
FSB - Memory Clock Mode - Unlinked
x FSB - Memory Ratio - Auto
FSB (QDR), MHz - 1700
MEM (DDR), MHz - 907
Memory Timing Setting
Memory Timing Setting - Expert
tCL (CAS Latency) - 4
tRCD - 3
tRO - 3
tRAS - 8
Command Per Clock (CMD) - 2T
** Advance Memory Settings **
tRRD - Auto(4) (4)
tRC - Auto(26) (26)
tWR - Auto(6) (6)
tWTR - Auto(10) (9)
tREF - Auto (7.8uS)
CPU Configuration
Limit CPUID MaxVal - Disabled
Intel SpeedStep - Disabled
PPM Mode - Native Mode
CPU Thermal Control - Disabled
C1E Enhanced Halt State - Disabled
Excute Disable Bit - Disabled
Virtualization Technology - Disabled
CPU Core 0 - Enabled
CPU Core 1 - Enabled
CPU Core 2 - Enabled
CPU Core 3 - Enabled
System Voltages
CPU Core - 1.60000 (1.52v)
CPU FSB - Auto (1.4v)
Memory - 2.200v ( 2.200v)
nForce SPP - Auto (1.40v)
nForce MCP - Auto (1.500v)
GTLVREF Lane 0 - Auto (+00mv)
GTLVREF Lane 1 - Auto (+95mv)
GTLVREF Lane 2 - Auto (+00mv)
GTLVREF Lane 3 - Auto (+00mv)
HPET Function - Disabled
Intergrated Peripherials
RAID Config
RAID Enabled
SATA 1 (A0) RAID - Enabled
SATA 2 (A1) RAID - Enabled
SATA 3 (B0) RAID - Enabled
SATA 4 (C1) RAID - Enabled
SATA 5 (B1) RAID - Disabled
SATA 6 (C0) RAID - Disabled
IEEE1394 controller - Disabled
HD Audio - Disabled
IDE HDD Block Mode - Enabled
Onboard FDC Controller - Enabled
Onboard Serial Port 1 - Disabled
PnP/PCI Configurations
Init Display First - PCIEx
Reset Configuration - Disabled
Resources Controlled By - Auto(ESCD)
PCI/VGA Palette Snoop - Disabled
PCI Latency Timer(CLK) - 32
** PCI Express relative items **
Maximum Payload Size - 4096
Edit: You could also try these settings for 3.4GHz (400MHz x 8.5), w/ the DRAM frequency at 800MHz...
Code:
CPU Core: 1.2500V - 1.300V
CPU FSB: 1.4V
Memory: 2.10V
NForce SPP: 1.4V
NForce MCP: 1.525V
HT Nforce SPP: 1.25V
FSB: 1600
tRCD - 4
tRO - 4
tRAS - 12
... w/ all sub-timings (Advanced Memory Settings) on AUTO, and disable all the Spread Spectrum settings
A
azace
Mesa, Arizona
System Clocks
CPU Multiplier - 8.5
PCIe x16_3, MHz - 100
SSP<->MCP Ref Clock, MHZ - 200
** HT Multiplier **
nforce SPP --> nForce MCP 5 x
nforce SPP <-- nForce MCP 5 x
x HT Spread Spectrun - AUTO
x PCIe Spread Spectrun(MCP) - AUTO
FSB & Memory Config
FSB (QDR), MHz - 1500
MEM (DDR), MHz - 800
Memory Timing Setting - Optimal
tCL (CAS Latency) - 5
tRCD - 5
tRO - 5
tRAS - 18
tRRD - Auto(3) (3)
tRC - Auto(23) (23)
tWR - Auto(5) (5)
tWTR - Auto(9) (9)
tREF - Auto (7.8uS)
CPU Configuration
C1E Enhanced Halt State - Enabled
Excute Disable Bit - Enabled
Virtualization Technology - Enabled
System Voltages
CPU Core - 1.25000 (1.20v)
CPU FSB - Auto (1.3v)
Memory - 1.850v ( 1.850v)
GTLVREF Lane 1 - Auto (+65mv)
HPET Function - NOT IN BIOS AT ALL
RAID Config
RAID Enabled
SATA 1 (A0) RAID - Disabled
SATA 2 (A1) RAID - Disabled
SATA 3 (B0) RAID - Disabled
SATA 4 (C1) RAID - Disabled
IEEE1394 controller - Auto
HD Audio - Auto
Onboard Serial Port 1 - 3F8/IRQ4
Init Display First - PCI Slot
A
azace
Mesa, Arizona
Everything is basically default except for the ones I said I changed above. Also, I get a floppy error when I boot for some reason and I have no floppy at all.
I would like to overclock the CPU, RAM, and Video Card to be stable with stock cooling if possible.
A
azace
Mesa, Arizona
Actually error is this: Floppy disk(s) fail (80)
Have to press F1 to bypass
Still get error even after I turned off OnBoard FDC Controller
What should i run to test the system stability?
redduc900
Inactive Moderator
Portland, OR
Check for RAM stability using Memtest86+ prior to attempting to boot into Windows, and for system stability use a program like Prime, LinX, Linpack, etc. in Windows.
redduc900
Inactive Moderator
Portland, OR
Click the 'All' button in order to utilize all available RAM, which in turn will maximize the Problem Size accordingly. Leave the Run times at the default of 20, and make sure to monitor the core temp's while LinX is running.
A
azace
Mesa, Arizona
Ok, how hot should the system get? Or will it stop if it gets too hot?
I am at 46% on the memory test now. Gonna be awhile more before its done.
A
azace
Mesa, Arizona
Okay, after only 1minute and 26seconds into LinX test using all of my memory, which was around 7GBs, the temperature reached a high of 85 Celsius.
How big of a difference can having to much thermal paste on the CPU make? I fairly sure I put way too much.
I got a Antec Nine Hundred Two case with 5 fans in it. My room is fairly hot because of the PC, like at least 10-15 degrees hotter then the rest of the house. Right now the temp is at 50 Celsius at idle basically.
Edit: I passed the memtest with 0 errors.
redduc900
Inactive Moderator
Portland, OR
A TCase of 50C at idle is way too high, and > 85C under load is also too high. Try reapplying the thermal paste, and when reseating the HSF make sure it's evenly seated and as square to the socket as possible. Your best bet though would be to invest in a better cooler.
A
azace
Mesa, Arizona
Okay, before overclock Idle was around 32 or 38 Celsius.(not sure)
What aftermarket cooler do you recommend?
EDIT: how big of a temp difference do you anticipate re-applying thermal paste will make?
EDIT2: System won't even pass with everything back to normal. 3minutes in temps reach 80 Celsius.
A
azace
Mesa, Arizona
Okay, I reverted everything back to normal factory settings and passed the LinX test. Here is a screenshot:
Here is the log of the test:
Code:
Intel(R) LINPACK 64-bit data - LinX 0.6.4
Current date/time: Mon Nov 23 12:56:00 2009
CPU frequency:    2.833 GHz
Number of CPUs: 4
Number of threads: 4
Parameters are set to:
Number of tests                             : 1
Number of equations to solve (problem size) : 29796
Leading dimension of array                  : 29800
Number of trials to run                     : 20
Data alignment value (in Kbytes)            : 4
Maximum memory requested that can be used = 2808999200, at the size = 29796
============= Timing linear equation system solver =================
Size   LDA    Align. Time(s)    GFlops   Residual     Residual(norm)
29796  29800  4      512.676    34.4020  7.973918e-010 3.192436e-002
29796  29800  4      511.404    34.4876  7.973918e-010 3.192436e-002
29796  29800  4      508.321    34.6967  7.973918e-010 3.192436e-002
29796  29800  4      509.131    34.6415  7.973918e-010 3.192436e-002
29796  29800  4      511.025    34.5131  7.973918e-010 3.192436e-002
29796  29800  4      527.041    33.4643  7.973918e-010 3.192436e-002
29796  29800  4      530.266    33.2608  7.973918e-010 3.192436e-002
29796  29800  4      509.617    34.6084  7.973918e-010 3.192436e-002
29796  29800  4      509.174    34.6386  7.973918e-010 3.192436e-002
29796  29800  4      508.736    34.6684  7.973918e-010 3.192436e-002
29796  29800  4      508.920    34.6559  7.973918e-010 3.192436e-002
29796  29800  4      509.107    34.6432  7.973918e-010 3.192436e-002
29796  29800  4      510.737    34.5326  7.973918e-010 3.192436e-002
29796  29800  4      511.133    34.5059  7.973918e-010 3.192436e-002
29796  29800  4      512.700    34.4004  7.973918e-010 3.192436e-002
29796  29800  4      516.322    34.1590  7.973918e-010 3.192436e-002
29796  29800  4      511.985    34.4484  7.973918e-010 3.192436e-002
29796  29800  4      510.810    34.5277  7.973918e-010 3.192436e-002
29796  29800  4      515.594    34.2073  7.973918e-010 3.192436e-002
29796  29800  4      514.818    34.2588  7.973918e-010 3.192436e-002
Performance Summary (GFlops)
Size   LDA    Align.  Average  Maximal
29796  29800  4       34.3860  34.6967
End of tests
Is this safe or too hot?
redduc900
Inactive Moderator
Portland, OR
With a 45nm quad running at only 1.152 Vcore, core temp's (Tjunction) of > 70C and Tcase of 76C under load are way too high. You need to get yourself a better HSF.
A
azace
Mesa, Arizona
I have the stock fan, shouldn't that keep the temps under those? I mean don't they run these same kind of tests?
A
azace
Mesa, Arizona
Okay last night I went out and picked up some aftermarket cooling. I picked up the Cosair H50(I know I am going to catch some flak for this but oh well).
I tested again on the stock CPU settings and the highest temps reached was 45 Celsius under load. It now idles around 29-30 Celsius.
Now would you recommend I try the overclock again?
