QDI ADVANCE 5/133 E AND P3 750 AND SLOCKET PROBLEMS-NEED HELP !!!!
Olly
Hi guys
I recently purchased a ready built combo of a QDI Advance 5/133E, P3 750 @ 1ghz , IWILL Slocket 2, and Golden orb. It had already been burned in by the person i got it off, but ive been having some problems lately, and want to check the configuration. First of all, on the motherboard, should the FSB be set at AUTO, 100 mhz or 133mhz ? Bearing in mind i am using a slocket ? Cuz i thought it should be set as AUTO on the board, and on the slocket at 133 FSB, with voltage of 1.85-1.9 ??? Is this correct ? Cuz at the moment i am trying to drop the FSB down to 100 to check it operates ok at 750 cuz had a few regirsty problems but can't seem to make it drop down. The system wasn't setup using softfsb or nething, jsut with slocket etc.. Also, when a motherboard manual normally says, for example, if there is a 2 pin jumper, OPEN means no pins connected, and CLOSED means the 2 pins connected using the jumper yea ? Anyone with experience with this board, overclocking the p3 750 or nething pleez help me. I am bit confused how the Slocket should be used and configured.
Thanks
everything youve assumed to my knowledge is correct. You should leave the MB to auto, and open means nothing is connected on a two pin, and closed means they are connected. The only thing I can think of is to set the motherboard to 100MHz and the Slotket to 100MHz, I dunno whether that will work tho, good luck, just play around with it a bit i guess.
