Quake 3 Arena + WinXP Qs
The Coolest
Senior Member
OK, my first question is can I somehow check for the version of my Quake 3 game, and if I can, can I update it somehow w/o downloading tens of MBs? My screen in Q3A in WinXP is very dimm and the brightness isn't changing when I move the brightness control in System->Display. I tried different vid cards, different drivers, even updated WinXP, nothing worked. Any suggestions?
Oni
Oni-ni-Kanab;, Ninja Hippo eater Moderator
St. Catharines, Ontario Canada
Try raising the gamma in-game. You can do that from the system configuration menu. As for the version number of the game, the most latest is 1.31, and the version you're running is displayed on the main selection screen in the bottom-right corner.
The Coolest
The Coolest
Senior Member
OK, my Q3A version is 1.11, I think its one of the ealiest. And where do I find this Gamma control, if its in the game, I can't see it.
If its in Windows, could u please pinpoint where it is exactly?
And how many MBs would I have to DL to get the latest ver of Q3A?
Thanks
BigRed
Caffinated Member
Mount Vernon, WA
Thanks
Hmm strange, i had this problem in Voyager: eleite force, i guess it fixed itself cuz i dont have the problem anymore :p
The quake 3 point release is only like 12 or so mb (not that bad). www.fileplanet.com is a good place to look (since gamespy and ID are in bed with each other theres not many other places to get it). and if you have last months PC gamer cd its on there as well :)
The Coolest
The Coolest
Senior Member
actually quake 3 point is about 28MB, but its OK. What will it do, and how do I install it? Will it fix the problems I'm having w/ Q3A & WinXP, cause I hear no1 else is having Q3A problems.
The Coolest
The Coolest
Senior Member
OK, thx very much I will try to do it, and will download it later.
The Coolest
The Coolest
Senior Member
It only downloaded a file w/ the size of 95KB, it wouldn't run, I think there is a problem w/ the link or the file that is on that link u gave me
The Coolest
The Coolest
Senior Member
OK, this one started the download, was only checking, will download it later. Thanks
phantom punisher
fort drum NY
yup the new point release 1.31 fixes it . i know because i just went through the same exact tning with version 1.11 and xp. i had to reinstall quake for a second time becasue i got a strange error at first. but 1.31 patch will fix the gamma in ver 1.11. have fun
The Coolest
The Coolest
Senior Member
OK, this is strange, I installed the point release after 2.5H download, and it did absoulutly nothing, maybe now I need to reinstall Q3A? Or how do I activate the update, I did go to "Mods" and load Quake III Arena but it did nothing.
fuzzba11
in the garage
There shouldn't be any menu changes, nothing noticeable between 1.11 and 1.31, I don't think, just a few tinkers.
To change gamma in Q3 bring down the console(hit ~) and type
/r_gamma
hit enter, it should be set to 1.0, you can adjust it to your liking :p
phantom punisher
fort drum NY
yea try reinstalling. the patch fixed my problem . as a side not when i reinstalled i did so with all my external gamma controls at default. im assuming the patch fixed it for me because i did nothing but that and fixed it
The Coolest
The Coolest
Senior Member
I just now tried to change the brightness, then I hit ~ got the console, it has lots of lines where it says: "SetDeviceGammaRamp failed"
I guess its my problem, does it tell u anything? Its now 23:37, so will be trying to reinstall tommorow.
Puer Aeternus
In your head (Ottawa.Canada)
In Q3 main menu do this:
go to set up-system-display..here is the place where you can change yer gamma...Also consider getting a new vid card...that may help out w/ your video prbs....and read the RTFM(read the F&%$'ing Manual)!!
Reinstall the game...re-apply the patch and all will be well..this game is idiot proof!
Win Xp works wonderfully w/ Q3 on my 2 systems..just read some facs and be patient....loads of sites out their that wil help you out w/ tweaks and stuff for your game...Check out "planet Quake".
http://www.planetquake.com/quake3/
Good luck:D
The Coolest
The Coolest
Senior Member
OK, I tried to reinstall Quake 3 Arena. It didn't work, it stayed the same, couldn't change the brightness.
