- Sep 2, 2001
- Elkhart, Indiana
I need to know how to see my fps
i have a gforce 3 and i stay constant at 90 so is there something i change to get over 90fps?
drdingo21 said:that didn't work either.... but i went into the cfg file and found it there, i now get around 250 fps at 1024x768 with the detal turned all the way up![]()
16 bits detail turned all the way upOverclocker550 said:
nice! are you using 16 bit and low details? I get only 1/4 that many fpsgeforce2mx and 550 celeron
The Coolest said:Why don't u set up 32Bit? it will look so much better?
So you'll have less FPS... The human eye can see only about 30FPS anyway. Higher than that is unnoticable
alien76 said:I am using celery 366, Gforce 2 pro, 256megs of ram and i play quake in resolution 1600*1200*16 constantly above 30 fps. So there is now reason to you not to play in very very high resolution, cause your system can handle q3 above 100fps even there is AA and anistropy enabled.
Just my opinion!!!
