Query
BabyEater
Dundalk Ireland
Ive set me watercooling up again but i am getting this whoosing noise out of it every 20 seconds or so. Is this air trapped in the lines and if so how do you get rid of it . I have a res by the way and it has been set up 3 days now.
hehe i know! the pump is sucking air! i had the same exact thing, it makes a little twister like in the drain and sucks air, its freaky! try to turn the pump or fill it up more or something, stick some kind of sponge in there i dunno, but just block it from doing that, deeper water will block it from doing that too
The pump isn't in the res its a maxi-jet which i made inline .It couldn't be helpin my performance much i might try and drain the system then refill it again
