question about bandwidth with wap
mbentley
Gloriously Lead, Overclockix Chief Architect
Indianapolis, IN
i have a question about bandwidth using a wap. i asked this in the folding irc room, but i had to go so i am not sure if anybody responded... anyway, say i have a 802.11g wap (which gives me 54mbps as my max bandwidth) if i have two computers connecting wirelessly to the wap, can they both (in theory) achieve 54 mbps or is that shared between the two?
mbentley
mbentley
Indianapolis, IN
DDR-PIII said:
they both should be able to have/use that amount of bandwidth each. :)
ah nifty :) i was trying to see if there would be any advantage of getting a wireless card for each computer or if i should use ics in the remote location if 54mbps was max for all the nics combined...
su root
Senior Member, --, I teach people how to read your
Ontario, Canada
don't quote me on this, but I'm 99% sure that wireless networks share a frequency range for all of the computers connected to the WAP. So that frequency range is like a hub network, all the bandwidth is shared between everyone connected, everyone broadcasts/recieves on the same frequencies that the WAP is configured on. Unlike a hubbed network (CSMA/CD), it uses CSMA/CA, Carrier Sense Multiple Access with Collision Avoidance, so there are very rarely collisions.
DDR-PIII
Disabled
6p6
Well I wasn't 100% sure about what Isaid, I was just going off of what I knew about wired LAN's, but yoy know more bout networking than me so I'm with you on this one :)
N
nerdlogic
Guest
I'd have to agree with su root. Although wireless has it's own properties, it's very similar to wired networks, and therefore, behave a lot like them.
mbentley
mbentley
Indianapolis, IN
hehe i figured that su root would come in here and pull out the technical terms :D thanks for all your guy's/girl's help...
it's not like i would be doing a lot of transfers at once or anything, just my curiousity got the best of me ;)
su root
Ontario, Canada
.. as I said, I'm not 100% sure, but from my understanding, it's a shared medium.
I'm sure a few of you have connected to verrry slow WLANs before, where there were people on there downloading/xfering stuff, and your connection is suffered because of it.
