Question about Catalyst drivers.
cannibaltrout
Why the hell is it that the Vertical Sync option changes in like every driver release? sometime it's a slider that you can set to force vsync, sometimes like with the 3.4s it's a button that you can on have off or app prefrence but not force????? I want my damm VSync forced on everything :-(
PreservedSwine
Ft. Myers, Fl.
It's been a slider for a while. If you still have a button, you might not have the right control panel installed. Each set of CAT's uses a *different* control panel. If you try and use the same control panel for (2) different set of video drivers, wierd things will happen. I *think* it's been a slider for the last 4 releases of CAT's. It's never gone back to the button. If it shows the button for you, uninstall, then re-install the proper control panel for your version of CAT's.
