- Aug 2, 2012
I'll put the tl;dr at the top in case it's a really obvious question.
tl;dr
What does the /mount directory do? Generally wanting to make sure setting a second Steam Library up will mount and function without any problems.
Now for the longer version...
I just recently had Mint 16 start to tell me my SSD was completely full, even after uninstalling most all of my Steam games, and clearing out their respective folders in the home\.steam\steamapps folders. So I figured since 17 just came out, as good a time as any to just blow everything away and start over.
Linux is still housed on my SSD Entirely, with the following Partition Table, all EXT4 format:
/boot: 535MB
Extended Partition :127GB
- Filesystem Root: 30GB
- /home: 92GB
- swap: 5GB
I currently am on a day-old installation of Linux Mint 17 Cinnamon with little more than drivers, updates, Steam and a handful of games. I am definitely needing to install the rest of my games on a secondary Hard Drive.
However, I notice whenever I mount a drive, some data seems to be written / accessed from the main disk in a /mnt directory. Now, forgive me if I'm misreading how it works, but the way it appears to me is that I would not be able to install more games than the SSD would hold in the first place, since the data still has to be mounted and go through my main drive instead of being independent. I have come to this conclusion because when I try to create a new folder / partition on a larger drive (looking at 200GB Partition on my 640GB Caviar Black most likely) it keeps making me choose a mounting point somewhere in my local filesystem.
Again, sorry for my ignorance but why does the mounting point of a secondary Hard Disk have to be on the local disk at all? And how much of that data has to go "through" my SSD's filesystem to get used, and how do I minimize any issues that may go along with that.
I did manage to get TF2 completely functional with FPS Config and HUD in a Linux installation, though, which is fun! I just have too many games to fit them on the SSD, but I like the snappiness of having the OS and main filesystem on the SSD, and some of my online games, or more immersive Single-Player games (TF2, DOTA2, Portal 2, and Metro: Last Light). I can install all my indie games on a slower drive, though, and wait 5 extra seconds to play the game if I need to.
Thanks for any and all help, as always.
tl;dr
/boot: 535MB
- /home: 92GB
- swap: 5GB
