Question about External Freq. Setting. A7V 133 Duron 850
Spidey
Hope someone helps me out here.
I am running my 850 duron @ 1.01 G at the moment.
Seems stable @ 1.72 volts on the core. About 45C.
I was wondering about these multiplyers.
At the moment they are set @ 100MHZ and 10.0x
I have Micron 133 ram and I am not sure what I should be setting the dips at.
Thanks guys.
So far all your comments got me this far.
in your bios you should have a option to have your clock +PCI so if your running 100 FSB then your RAM is running 133
read your manual and see where in the bios it says to do it
hope this helps and good luck
