hi everyone although im not new ive been away a while.i have a kt7a-r with phase 1@2 voltage mods as well as the 5v mod.i am stable at 1560 2.08 vcore.i am currently using the thermoengine with delta 7000rpm.if i could raise my voltage slightly and/or keep my temps down i feel i could get 1600 stable(my aircooled goal).
in your opinions would a gladiator with the "funnel adapter"and one of those 68cfm 80mm delta fans(using the 80 to 60mm funnel adapter) with some AS2 be a significant difference in temps over what im using?my thermal compound is not as2 either by the way.im getting about 54c full load with the thermistor bend up where it contact the bottom of the cpu(i have to actually hold down while i close the zif lever)
if you have any suggestions or opinions i would appreciate them
