- Oct 5, 2001
- Ottawa, Canada
Emericana said:i am about to start to attempt to lab using yodums method w/ 2000 grit... just in case it did not work, i got this stuff at auto zone 3m rubbing compound fine cut... this is NOT POLISH. It removes the scratches from the bottom of metal and was designed to be used w/ 3m sandpaper.... does anybody have any comments about wheter or not to use the rubbing compund?
Don't use anything on the base. No lap guide you find will tell you to do this. It may degrade the performance, as we know people already tried this and there was no gain. The thing is that it may just fill the scratches with something, that makes the scratch no visible and the thermal compound on the base of the heatsink will have no effect.
