Question about Nvidia drivers
rush
Hi i have geforce2 GTS and im using official 6.50 drover from nvidia i see there is alot other beta ver are out anyone would recomend geting them ? if so what ver should i grab, thanks.
dunno then, I run WinMe dual boot with Linux SuSE 7 Pro
I have 6.5 for my GeForce 2 Mx and its fine.
U only need a driver update if ure graphics card if u have stability problems or want to squeeze the last drop of performance out of ure card.
I use the 12.xx detonators, windows approved (WQHL or whatever) from here or even here.
I am not home right now, if you email me I can send you to the link I downloaded my drivers from later. Hope this helps.
I have heard from alot of people that the 7.76, 1080 and 1101 drivers are THE fastest drivers to use for any of the newer nVidia cards
