Detail technical specification -> HERE or it's PDF datasheet -> HERE
Courtesy of Sanyo Denki
Planning to use it on friend's custom case for blowing the mobo's bottom/back side and his case has room for 25mm fan on the right panel.
Looking at the spec, the noise is 48dbA at full speed, wondering if it will be "relatively" silent when undervolted, the datasheet doesn't put any noise chart in it.
Has anyone ever try or use this fan ? Please share your experience if any, TIA.
