I have an IC7-MAX3, P4 2.8c, and sp-94 hs.
My case came with a temperature probe to put under the CPU, but it didn't quite fit so I attached it to the side of the heatsink near the bottom.
Will this give me fairly accurate readings? Right now the MAX3 is reading about 45deg C while my probe is reading 30.
I know there are claims the MAX3 may read a little high.
Which method do you think is giving me the most accurate temperature reading?
THANKS!
THANKS!
