- Feb 15, 2018
- Right here.
I have been playing around with 2 systems and found out something very interesting yet do not know what do you think.
I have been messing around with over clocking and found that when temps get high on the "System" ( Or what I assume is the North bridge ) the system fails.
This has happened several times where I have increased the NB voltage to get not only higher clock speeds but higher RAM speeds. Say I use 1.2v on the NB the temps will stay around 75-80*c but when I push the voltages say 1.25v or even 1.3v, this is where things get interesting then say you start to OC that RAM now the NB is now at full speed! 100% usage and starts to heat up like crazy it goes into some kind of strange heat generating cycle as where it was fine before you messed with that RAM now it is getting past 80* going to 90*c NOW it is at 100*c!!!
CPU is only at 50*c everything fine till shut down!
Now this could just be from a bad OC I know. But this happens exactly the same way on 2 different systems completely! Once you start to load up that NB with voltage and ( what I would assume to be frequency ) the system is also unstable and will fail. So as for Over clocking my Rijaws Ram on my FX it is Not going to happen with an Over Clock on the CPU of 4.4GHz.
Same with the Ryzen.
Is anyone else finding this out? This is Not a BSD or some error this is a restart shut down. You get No error messages. And no way to get a screen shot of HWm.
Any one know what all the TMPIn1 sensors are?
So I have backed the voltages of the NB to auto and do not over clock the ram it is all on auto. no heat issues at the same CPU clock speeds.
Seems like the weak link for AMD is that NB and the VRM they still get hot ( granted Not as hot as the old 970 chipset ) It would seem that if this is known there would be some improvements coming from the MB industry yet we still seem to get sub par parts boxed in eye candy so you buy it? seems like if not for the heat build up from the NB I could actually get MORE from my CPU.
Any thoughts maybe I am way off base I am stone right now and just board thought I would share this little bit of info I have been having issues with.
