Question for those with Coolermaster 201/Praetorian cases
james__bean
Eugene, OR
How do the fans mount behind the front bezel? I have a 220b that doesn't have any fans on it and I'm thinking about changing out my front with the 201's. I'm pretty sure that I can swap them out no problem but I'm curious as to how I could get the fans in there.
FIZZ3
NL, Europe
There are mounting extensions on the front end of the drive cage. These lie about 1cm behind the front grille. You can use normal fan bolts to attach two 80mm's there.
