Question From one of my Customers.
HardCaze
Gold Coast, Australia.
Hullo OC.net,
one of my customers asked me how fast the rig im building for him will render objects in Photoshop (i personally don't use PS so i wouldn't have a clue)
The build is;
i7 2600k
16gb 1600mz CL9 RAM
P8Z68 mobo
GTX 570
SATA 6gb/s SSD
He is in marketing and his current pc is taking ages to load any image.
If he's not worried about money; yeah looks solid. Is he even a gamer? What resolution screen does he use?
What case/PSU you running?
If he's not a hardcore gamer; consider a GTX 560 Ti instead.
Consider a Fractal Arc Mid tower case.. IMO it's nicer.
TX850 is overkill; and non-modular.. potential mess. GTX 570's could run SLI with 750W.
Consider Corsair TX 550M instead. Partially modular; and not overkill.
But if you're willing to extort him for something he doesn't need... Your choice :p. (Mid-moderate gaming offers a GTX 560 Ti or HD 6870 at best.. No need for more at 1080p or less for a casual gamer :\).
What would be the PS CS5.5 performance on the rig? (main question i asked)
like how long would it take to render an image with heaps of layers/large file size?
Well if his work is paying for it.. Who cares! Though I still suggest a different PSU. A modular one if you can.
Asking a broad question like that with heaps of layers + high res files... Won't get any answers frankly.. I'll assume he's using older tech.. Say Core 2 Duo quad core non-oc.
http://www.anandtech.com/bench/Product/287?vs=53
That's a Q6600 vs a 2600K. It retouch's over twice as fast (favoured for the 2600k).
And that's at stock.. I assume you're getting a K model because you're going to overclock it..? If you're not.. get the non-k model? Or even one of these, Intel Xeon E3-1240, though that would no longer really warrant the need for a Z68 board..
I see. Could probably run that on stock volts no sweat. And on the stock cooler (though I'd still recommend a Hyper 212 Evo or Thermalright True Spirit or something along those lines..)
judging by the Anandtech and Tom's hardware models, I think you can say 'Things should render about twice as fast, give or take a bit' -- Assuming the old PC was a cor2duo with a decent GPU.
Hullo OC.net,
Dot com ;) Overclockers.com >> Overclock.net :cool:
The build is;
i7 2600k
16gb 1600mz CL9 RAM
P8Z68 mobo
GTX 570
SATA 6gb/s SSD
Looks good to me for photoshop - maybe just add a ~0.5 -1 TB HDD for storage and you should be good to go. I hear Photoshop works better on nVidia cards so you've got the right sort of setup there. I suspect PS might make use of faster RAM (2133 MHz?) but I'm not sure.
Welcome to the forums :thup:
Hullo OC.net, one of my customers asked me how fast the rig im building for him will render objects in Photoshop (i personally don't use PS so i wouldn't have a clue)
The build is;
i7 2600k
16gb 1600mz CL9 RAM
P8Z68 mobo
GTX 570
SATA 6gb/s SSD
Ask him to load PS on this machine and then run this benchmark: http://www.hardwareheaven.com/photoshop.php
That will give him the information that he needs. :D
