I have a HP pavilion a375c computer specs are as follows:
key specifications
Microprocessor
Intel®
Pentium ® 4 processor 3.00GHz with Hyper-Threading
Hyper-Threading Technology
Secondary-Level Cache (L2)
512KB
Front-side Bus
800MHz
Memory
512MB PC2700 DDR SDRAM memory (expandable
(expandable to 4GB)
Hard Drive
160GB 7200RPM Ultra DMA hard drive
Multimedia Drive
DVD writer and CD-writer combo drive (DVD+RW/CD-RW)
(DVD+RW/CD-RW)
DVD-ROM
DVD-ROM drive 16x max. speed
Video Graphics
BFG 7800gs OC AGP card
Network Interface
Integrated 10/100Base-T network interface
Sound
Integrated AC97, 6 speaker configurable
Memory Slots
4 DIMM (184-pin DDR) (two available)
Memory Speed
2700 MB/sec (PC2700)
Fax/Modem
High-speed V.92 ready data/fax modem
Drive Bays
2 external 5.25"(both occupied)
2 external 3.5" (both occupied)
2 internal 3.5" (occupied)
Expansion Slots
3 PCI (two available)
1 AGP (occupied)
Front Mounted Ports
7-in-1 digital media card reader
1 FireWire (IEEE 1394) port
2 USB 2.0
Microphone/Headphone/Line-in
External Ports
Front panel 7-in-1 digital media card reader [supports
[supports Compact Flash I/II, SmartMedia, Memory
Memory Stick, Memory Stick Pro, MultiMediaCard,
MultiMediaCard, Secure Digital (SD) and IBM MicroDrive]
MicroDrive]
6 USB 2.0
2 FireWire (IEEE 1394) ports
1 Serial
1 Parallel
2 PS/2 (occupied by mouse and keyboard)
1 VGA
External Ports
6 USB 2.0
1 Serial
1 Parallel
1 VGA
Product Number: DQ110A#ABA 10/08/r2_SL©2003 Hewlett-Packard Company
(a)
http://h10025.www1.hp.com/ewfrf/wc/product?product=376094&lc=en&cc=us&dlc=en&cc=us&lang=en
The problem that I am having with this computer is heat!!! It gets much to hot inside the case. I was wondering how hard it would be/expensive to change all the parts into another case with more room for airflow/extra fans. Also if it is possible, could someone recomend a case? Thanks in advance for you help!
key specifications
Microprocessor
Intel®
512KB
Front-side Bus
800MHz
Memory
(expandable to 4GB)
Hard Drive
Multimedia Drive
(DVD+RW/CD-RW)
DVD-ROM
Video Graphics
Network Interface
Sound
Memory Slots
Memory Speed
Fax/Modem
Drive Bays
Expansion Slots
1 AGP (occupied)
Front Mounted Ports
2 USB 2.0
External Ports
MicroDrive]
6 USB 2.0
1 Serial
1 Parallel
1 VGA
External Ports
6 USB 2.0
1 Serial
1 Parallel
1 VGA
(a)
