question on conductive pens
Dragonbud
Orange County, California
Going to pick one up from a local electronic store after work.
I have this big urge to unlock my 1800xp and would not be satisfied til i' try.
If i screw up on the bridges, is it fairly ez to undo using conductive pens?
what solution can i use to remove the ink just in case *&^% happens?
any help/info would be greatly appreciated.....
Sonny
Senior TIFOSI
VARIANTE ASCARI
It's very easy to clean up the traces from Conductive Ink Pens. They are really just real silver paint dispensers so cleaning them up with solvents that do not harm your chip.
I have found acetone/finger nail polish remover(the old awful smelling type) works really well & has no adverse affect on the chip.
One thing that a few people seem to neglect when unlocking their chip is to properly fill in the pits with a suitable substance. Crayons/Wax jobs seem a bit on the adventurous side to me since heat can melt it. I suggest super glue as the simplest & most affordable solution to this. Now there are a lot of people that don't want to use this claiming that if they have to redo it cleaning off the glue is a pain in the @$$. Why does anybody have to clean up the glue????? All you need to redo is the paint. Below are other ways on how to fill in the pits;
Permanent - Tamiya 2 Part Putty. 2 sticks of clay like substance mix/twist together then rub into the pits/slits of your XPs. Wait a few minutes to harden then bridge L1 dots with conductive ink penn. Clean & easy
Reversable - Chemask Squirt it on wait a few minutes then bridge L1 dots. Simple & fast. Great for soldering/volt mod jobs too.
CW2200MTP Conductive Ink Pen
I also tried some typewritter correction fluid(the white stuff) & have been succesful with it. The paint sticks to it really well & is very easy to apply with a pin.
Kato
Addicted Tweaker
Toronto, Canada
Hey Sonny, can you give me a site where i can order the conductive ink pen? or can i get it from RadioShack?
Sonny
Senior TIFOSI
VARIANTE ASCARI
LOOK HERE to find the nearest distributor for the pen. FREE SAMPLES are also available from them. All this links were on the pages I originally linked to. CHEMASK is one product that you guys should really take a look at.
The RATSHACK doenst carry the pen in their stores but they do have it online.
