M1dn1ghtN1nj4
- Dec 26, 2017
I just bought this kit from ModMyMods. I have a project I'm working on, and got a discount from the site owner.
https://modmymods.com/modmymods-raspberry-pi-mini-water-cooling-kit-mod-0171.html
I wanted to add in this coolant:
http://www.xoxide.com/mayhem-auroragalaxypurplecoolantconcentrate-250ml.html
Will this work, and be safe/compatible with my flex tubing? And possibly PETG hard tubing for a later, upgraded build? It says it's safe for metals, but doesn't mention plastics. My reservoir is also plexi. I want the pearl effect, if possible. If you can think of a better brand, with compatibility with all component types (PETG, plastic, plexi, metals) and has also a purple metallic format like that, let me know.
This is a second coolant I'm looking at. Supposedly, PrimoChill Vue holds up better. I also don't want one that will kill my nickle plated cooling blocks.
https://www.primochill.com/collecti...ochill-vue-pre-mix-32oz-primochill-uv-blue-sx
My radiator is copper inside, so I SHOULD be safe.
Remember, this is my first ever liquid cooling build.
