Unless you have a specific problem that is corrected with a new BIOS, you should probably leave it alone. Such problems may include, new signatures for newr processors, fixing lock-up problems, IDE issues, etc. Any of these issues will be noted at the web page that you get the BIOS from. Look it over carefully. If you do not have an issue, you don't need to update the BIOS.
