- May 31, 2009
- Citrus County, FL
Ok, so I know this could probably go in the GPU section of OC Forums, but I wanted to throw this out here since it's directly related to seti.
I've been told that raising the Shader clock on my GTX 260 helps with crunch times, but don't overdo it.
Well I've noticed even 40mhz helps in regards to about 45 seconds per 10 minute w/u which is worth it to me, but my problem is occasionally I start getting computational errors on cuda w/u's with the overclock. Is this something I'm going to have to live with, or should I just leave it at stock speeds?
