Question to Barton users
DDR-PIII
Disabled
6p6
How many WU's are you putting out in a 24hr period ? Tommorow I'll be picking either a 2500 or 2600 up, there is only a $20 difference, but I'm not yet sure if it is worth that 90Mhz heh. Also What kinda hardware setup do you have inorder to get "your ammount" of WUs/day ? thanks.
MuEagle05
N/A
I think i can get about 7-8 a day. Right now I'm overclocked to the equivalent of a barton 2800, so i'm getting about 12
My setup: 512 ram, barton 2500+, chaintech zenith mobo, watercooled
Thoth
Barton Results
i have a Barton AQXEA 0321 UPEW
2500+ @ 2368mhz (10.5x225) ram @ 80% (crappy ram) watercooled...
i'll give you a range here... it did a 7.671AR wu last night in 1.83hrs... it did a 0.432AR wu in 2.12hrs
Hope this helps! :D
edit : it gets 12-14 per day depending on AR
psyshack
Okmulgee, Ok.
Im getting 11 to 13 per. day with mine.
OC 2.3 ghz, msi k7n2, a mix of corsair and kingston val. ( both bh-6 chips ) sk-7 w/80mm tornado. 210x11 the cpu is locked. AQYFA 0344. Far better slug than the xp1700 I had in the machine.
DDR-PIII
DDR-PIII
Disabled
6p6
ok thanks guys, im gonna hold off on getting it untill i can buy everything in one shot "mobo cpu, drr 400 dram and a new hdd" :) i would just die only having the cpu and nothing else haha. argh guess maybe anohter week or so.:(
gusgizmo
Disabled
Kona, Hawaii
hmm... now ill have something to shoot for with my new barton. i cant wait till my new bios gets in and i can boot the crazy thing. kinda funny that it will do 4 times as many wu's a day as my other three machine put together. but hey, every little bit helps.
also, does anyone know how many wu's a day a 1GHz thunderbird will do?
