SOLVED question
T
theo
Guest
I have a custom built computer with a motherboard that says it will except up to a 533 celeron or a 800 p111. I am unable to find the name of the board without pulling apart the case agine and I don, want to pull apart the board at this time. It has two slots, the 370 socket and the slot 1. It has three memory slots, one pci and one isa slot. All peripherals are on the board. It is sold in Gobal but has no name other that a part number of z-748.
Thanks Theo
When you boot the machine the BIOS serial number will apperar at the bottom of the screen. You can use this number to identift you MB.
check these links
motherboard homeworld
windrivers.com
This your board?
[img=[URL]http://store4.yimg.com/I/zerus_1615_887249[/URL]]
M748LMRT System Board
This board has been replaced by the Z-7306 Motherboard
CPUs
Slot 1: Pentium II/III or Celeron(SEPP) at 100MHz or 66MHz Bus
Chipset
100MHz SiS 620 (Xl2000) AGP chipset
Video
Embedded SiS 6326 AGP Video chip,supports shared system memory up to 8MB . Chipset integrated Hardware Motion Compensation to improve soft DVD video Memory
Three 3.3 volt, 168-pin DIMM
sockets Up to 768 M SDRAM
I/O Expansion Slots
One 32bit PCI slot
One 16bit ISA slot
System Bios
AMI PnP BIOS
2M Flash ROM
Supports ACPI and Legacy PMU DMI support
ACPI/APM power management wakeup External modem
Hardware BIOS virus protection Power Features
AT/ATX Power Connector
Supports ACPI, Wake on LAN, Alarm Wake Up, Keyboard Power On, Suspend, Soft-off functions
10/100 LAN
Hardware Monitor
Detects CPU temperature, fan speed and current voltages
PC Health Monitoring, which allows you to protect your system from problems even before they occur.
Get the details here: http://www.shop-at-zerus.com/z748.html
please help me!!! I'am haveing the same problem all my motherboard says is Made in Taiwan R.O.C. model # V66XA and some numbers at the end I don't know what they are for they are: 97168-1
question : thanks for the help,theo
Shadow (Jan 06, 2001 04:41 p.m.):
This your board?
CPUs
Chipset
Video
I/O Expansion Slots
One 32bit PCI slot
One 16bit ISA slot
System Bios
AMI PnP BIOS
2M Flash ROM
10/100 LAN
Hardware Monitor
