A
Ariel
Guest
Hi All,
Well the 1.33ghz (266) chip came in Saturday.. unfortunately it was an AVIA code and is not an exceptional performer although it does okay. I did a thorough pencil job on it, put on the artic silver paste and installed the FOP38 HSF. After putting the motherboard back in the case I began testing to see what this chip could do...
Iwill KK266R motherboard v1.2
04/26 bios
(2) 256mb Crucial Cas 2 pc133 sticks
Geforce2 GTS 32meg agp card
Detonator 12.10 drivers
SoundBlaster Live 5.1
Windows XP Beta2 build 2462
Results:
The highest cpu speed I could reach stably while playing Quake3 was 1404mhz (10X multiplier and 140mhz fsb)
The highest fsb I could reach was 149mhz (9X multiplier for an overall speed of 1342mhz)
Observations:
I was really hoping to reach around 1.5 ghz but once I saw that the cpu code was AVIA I really didn't think I had much chance. I have a couple of concerns however..
[1] To reach 1404mhz I had to significantly bump up the core voltage. According to the IWILL Smart Setting it should be 1.825 but according the Bios's PC Health Status and Motherboard Monitor 5.06 it is 1.96..
Which one is correct?
And if it is really 1.96, is that too high? Will it kill the cpu?
(2)The cpu temperature according to MBM 5.06 is 43c at idle and 46c under load
The motherboard is 30c at idle and at load. There doesn't seem to be too much difference between idle and load so I am not sure how accurate that all is..
Thanks,
Ariel...
04/26 bios
Results:
Observations:
Thanks,
Ariel...
