- Jul 15, 2013
so as most of you know i have an X58 setup LGA 1366 based around the xeon w3690. i think my xeon CPU has a bad memory controller because with 6 sticks of 8gig ageis gskill ram the bios and windows 10 will only see 32 gigs and windows says only 4 of the 6 slots are used. interestingly enough both cpuz and speccy can see the full 48gigs of ram
my question is how well would the i7 960 perform in gaming i mainly play shadow of the tomb raider and doom 2016 my gpu is a 1660Ti i know id be going from 6 core 12 threads to 4 cores 8 threads but i cant afford a new system at the moment money is tight the 960 was given to me for free
also how well would the 960 overclock i was able to hit 4.5GHz on my 3690 thanks for your time
edit this gaming system is just a temp pc till i can save up money for a new ryzen system next years
dont wanna toss in the 960 if it wont overclock as well as my 3690 did
so do i keep my 3690 in my system knowing it only sees 4 out of the 6 ram stick due to the bad mem controller or toss in the 960 and risk a lower overclock?
cpu memory controller was bad problem solved
