Ok, here's my setup......
T-Bird 1Ghz @ 1236 9.5 X 130
KT7A RAID
3D Prophet GTS 2 Pro 64mb DDR
128 mb Mushkin PC133 REV.3 @ 130Mhz cas 2
Globalwinn - FOPP-32
Creative 12x DVD w/dxr3 decoder
Creative 8x4x32 cdrw
2 IBM deskstar 30gb drives 7200 rpm both with ultimate HD coolers. Soundblaster live! x-gamer
Addtronics 6890A full tower
4 80mm case fans + 1 92mm
My questions.... how safe is it for my AGP bus to run @ 86Mhz and my PCI busses to run @ 43Mhz ? I ran Sandra burn in test for 2 hours straight without any problem with a maximum cpu temp of 105f and an idle temp of 76 to 78f. I am sure temps will go higher than that while gaming, do you think im safe? I would appreciate any answers as well as any suggestions from the pros.......thanx in advance....
Here are some bench results:
CPU: 3460/1689
Multi-Media:6897/8361
Mem:ALU:445/FPU:500
KT7A RAID
CPU: 3460/1689
Mem:ALU:445/FPU:500
