What command do I need to add to make the client not download and start a new work unit? I need it to stop so that I can remove it and download a "dual" so the pentium d can run to instances of folding.
you can also use -pause flag ... i haven't used -oneunit but pause just makes the console sit there and wait for ctlr-c.
I use that on my folding instances that are not running as services (all of them atm). Since there is no UI for a service i assume -oneunit is the only way to do them if you leave the service running?
versus stopping it and running the instance as a normal console with the -pause flag in the shortcut properties instead of regediting?
