Quick corrosion question: Dtec Pro Core & MCW6002
klath
Bay Area, California
No, brass and copper will not corrode with each other and considering the MCW6002 is an "all copper construction", the the two items will not corrode, however, I can't speak about other items in your loop, if your GPU/NB block has aluminum, I still recommend antifreeze or a corrosion inhibitor.
Maximus Nickus
Senior Shaman
Milton Keynes, U.K.
Have you considered using Water Wetter? If you are unsure as to the other components in your system then Water Wetter helps lower corrosion, and it will lower your temps as well.
M_N
klath
I think most people would agree with me that the general concensus is that antifreeze works better than water wetter in terms of residues clogging jet impingement style blocks, stains on tubing, etc.
=ACID RAIN=
Kingwood, TX
Yeah, from what I read, waterwetter aint that great. It's a holdover from when we were still researching what is "best" for watercooling.
Sp00L, if you want to stick with copper+brass water coolling, but you want to cool a GPU, use the fusionHL. Its a copper base with a brass top. I use it with a whitewater, and no antifreeze. It's been this way for around 5 months, zero corrosion. All I have is a little green automotive leaktest dye for color ;)
Korndog
California
you forgot about the smell
oh god does it smell..
S
sp00L
Buffalo, NY
I'll keep that in mind. I've also read that a few people are using windshield washer fluid instead of anitfreeze or the Zerex RC fluid. Thanks for the advice. Everything will be here tomorrow.
