- Dec 14, 2004
- Charlotte, NC
I did some high end testing and I was able to get my E8400 to boot at 500fsb/4.5ghz. I was thinking that my system would crap out before 500fsb but after reading this thread (629fsb on air with P5B-D C2/E8500):
http://www.xtremesystems.org/forums/showthread.php?t=175562
It appears that the Asus P5B-D C2 revision clocks FSB like a mad man.
So...I want to test my max FSB/ram settings but I have a problem. I can't change the multi on my E8400 in the BIOS. The only option is Auto, there is no choices or drop down menu.
Do I need to reenable one/all of the power saving features to regain the ability to change the multi? I currently have them all disabled.
Thanks.
EDIT: I'm also having problems with Prime95 25.6 crashing instead of giving errors. Is this normal? I remember when I pushing my E6600 it would give errors and halt, not crash out of the program. I'm currently working on my 490/4410 stability in Prime but I can't get it to run for more than 5 minutes without crashing. SuperPi and PCMark05 both love the setting I am currently at. I was able to pass PCMark05 with 1.424v @4410 but I can't get Orthos to run for 5 minutes with 1.512v.
2nd ninja edit: Prime95 Blend test works great so far. Can't get the CPU stress test to run at all though. :/
Thanks.
