Quick Maze4 GPU question
klath
klath
Bay Area, California
My Nvidia GeforceFX only has 2 mounting holes in the card. Like you said, I figured I can just move the two screws into the inner holes (or maybe outer?) but I wasn't completely sure and didn't want to buy a used ATI one without knowing it would fit on my Nvidia.
lithker
dont worry
i have an evga 5600 ultra and i purchased the maze4 ati version from dangerden and it fits u have to use the 2 outer holes only thing that sucked is i had the remount it cause the all treads were running into my zalman northbidge heatsink so i had to cut about 1cm off the threads keep that i mind if u buy it
