- May 24, 2001
When sealing your 370 motherboard with silicone how far up the base do you put your silicone? Do you just fill in the bottom or do you keep going up onto the cold plate, peltier and up to the bottom of your waterblock? Or should I just do silicone around the base and then use my neoprene foam to cover the sides of the cold plate, peltier, waterblock ??
