NeoMoses said:yep, with watecooling, you'll be able to bump up the voltage and still get rid of the heat. My AXIA has hit 1530 at 1.85V, but I'm only using air cooling, so it wasn't that stable. I know she's got more speed in her, if I could only get rid of the heat!
Yodums said:
Where'd that rig go as it's not in your signature?
Xantec said:hmm. out of curiosity, how good is my t-bird's stepping for o/c-ing ? AYHJA
NeoMoses said:
that's the best TBird stepping. If I'm correct, all 1.4 TBirds are factory unlocked, and all that I've played with have been able to hit around 1600 MHz or better.
NeoMoses said:
that's the best TBird stepping. If I'm correct all 1.4 TBirds are factory unlocked (*edit: I was not correct ), and all that I've played with have been able to hit around 1600 MHz or better.
[peer pressure]
From your sig it doesn't appear that you're overclocking. Your temps look good, you've got a great cooler, and a good chip. What are you waiting for? Crank that badboy up and see what it'll do! [/peer pressure]
