Quick Question for All Asus A7A266 owners.... Bios related
_jubei_
Disabled
BROOKLYN, NY
How many of you run 1003 bios with 2 sticks of PC2100/1600 ram on A7A ??? IF yes, do you have any problems ? where your Windows would Crush after a while, or you use programs that use a lot of memory and after a while they crush as well.
I really need to know..... My system is VERY unstable with 2 sticks of 2100 ddr ram . I need to locate the Cause... Everything works fine with 1 stick of ram... I reinstalled everything at least 5 times... Now I use win 2Kpro , same problem ........
The ram is GOOD.... I think the 1003 BIOS may cause the problem.. I NEED YOUR HELP PEOPLE!!!!!!!!!!!!!!!!!!!!!!!!!!!
jubie I built a system for a guy and used the A7A I had alot of problems with this board .I couldnt OC 1mhz or it would freeze up I was not happy with it but I DO like everything else from Asus I own A7v 133/133 &A7v 200/266 and love everyminute of it I even went with the Asus cd rom 50x in 2 machines good luck to ya sorry I couldnt help
I fixed it. My problems were coused by BIOS 1003 .. I upgraded my BIos to 1004 and everything seems to work fine so far.. I no longer get errors while playing UT with 2 x 256 mb PC2100 . I will test my system for the next few days.. I will tell you later if everything is stable
Bobby Manus (Jun 03, 2001 04:56 p.m.):
Yikes your stories are making me consider a different mobo, I was strongly considering this mobo, anyone else have problems with it???
The only problems i have had with the board were when i was using bios 1003 or lower 1004 is working great. And ASUS put a resistor to damn close to the Cpu socket and I broke it off with the HSF clip and caused to board to not post. But othere wise I just love it.
