- Jul 17, 2001
- Denver, Colorado
trying to build myself another waterblock- this time I'd like something stonger than JB Weld.
I'm trying to join an Al base with a Cu cap- is there a particular type of solder/flux you guys recommend? Needs to work at relatively low temps- I'm using a stove instead of a torch.
The hardware store has like 3 kinds that will work at 450F, but they are not specifically labelled for use on aluminum. Does that matter?
