Quick SSD question
Alaric
Satan's Colon, US
Probably a dumb question, but... I will be installing a new OS on an existing SSD. Should I be concerned about read or write cycles with a full format, or is there anything I could/should do differently than on a HDD?
ATMINSIDE
850 EVO? Just use the Samsung software, it takes care of everything.
Alaric
Alaric
Satan's Colon, US
The Samsung software won't be installed on the drive when I install the new OS. Should I let Winders do the work or is there a way to boot in to the Samsung software on a flash drive and let the Samsung stuff handle it? Or am I way over thinking the whole process? Oh, and any idea why Windows is only showing a 465 GB capacity for a 500 GB drive? I understand the differential in the MB and GB ratings, but 35 GB exceeds that by a fair margin.
mackerel
Just do a fast format. No point in a full format.
465 computer GB = 499,289,948,160 B. Close enough.
ATMINSIDE
Just install to it like normal, then install the Samsung software.
The multiplier from manufacturer bytes to PC bytes is 0.931x which puts you at 465GB.
Remember, Windows pulls part of the drive for a reserved area as well.
ATMINSIDE
Seems like a pretty big gap at 35 GB on a 500 GB drive but that's exactly how Windows sees it so I'm moving on from that. Thanks!
Manufacturers say 1GB = 1,000,000,000 Bytes.
Operating Systems say 1KB = 1,024 Bytes, 1MB = 1,024 KB, and 1GB = 1,024 MB.
1/(1024x1024x1024) = 0.931322574615478........ AKA 0.931x :thup:
