Quick WaterCooling Question
gkeuler8
Just a Few Quick questions On Water Cooling, Im looking into building my own (btw im on a budget... which should be obvious, lol) Where Can I buy cheap Waterblocks and Pumps and also do I have to buy a brand pump like Eheim Or can I just go to Home Depot or someplace like that to find a pump.
As I Do more reasearch i should have some more questions, Thanx for the help anyway
G
gkeuler8
Also Is it possible to make your own waterblock? and if so are there any resources on the web for this?
CZmanz19
Littleton, Colorado
I made the mistake of buying a pump from home depot and they dont do to well inline. I would be safe and maybe wait a little to get quality stuff because you dont want it to leak and ruin your system. Also i would suggest buying a DangerDen Maze 3 block which isnt to expensive and performs well.
G
gkeuler8
when I saw people making there own blocks and that it was cheaper i wantedto make my own but it's pretty intimidating...
