I'm looking for a HSF combo that is very quiet-That will probably be less rpm's but I don't d any overclocking. Some suggestions please.( maybe type, rpm, and dbm)
Zalman's! Uses a 92mm with a fan mate that you can control the fan speed via a rheo. I just bought the fan mate for my P4 stock cooler. I am a shhhhhhhhhh nut!
I thinking of doing that Alpha Papst combination and was just wondering what temps you get on that? ...I'm not an overclocker, so hopefully higher temps shouldn't be to much of a problem
I have a 1800+ XP by the way, think it could run with this combo?
I've been reading some reviews on the Glaciator Lite and Glaciator II. Just wondering what type of glaciators you guys are using? ...What Db and CFM ratings do they have?
