R5 340x rebrand R7 250?
Shiozaki
340x seems easier and cheaper to find with 2gb of gddr5 then the 250, i want it to tinker with apu dual graphic setups.
i guess this question extends to the r7 350 as well i cant tell if its a rebrand of if it will work.
[email protected]
Israel
If you want it for gaming, Dont.
See if your APU supports the card then tell us.
bob4933
An 8580 cannot do Dual Graphics.
...and where is he saying he wants to use his 8350 for this? He's quite specific about using an APU, and given his prior posts, its pretty clear he knows the FX series are not apu chips.
ATMINSIDE
Anyone coming by who doesn't know systems as well could assume he is referencing the FX-8350 in his signature.
That post was to make it clear to anyone that an FX cannot be used for Dual Graphics.
ssjwizard
Has slightly less legible writing than Thideras
So I did a little bit of research on this and it seems like the GPU architecture used in the 340x is a little bit more modern than what is used in the A10 lineup. It may work, but I would not be completely confident in it. The R7-250 and R5-340 have very different specs. Now it may work, but you might be handicapping the GPU. Dual Graphics is a fun tech to play with, but it tends to be a bi specific in what it will work with.
