MY PC SPECS:
I have a FX 8350 OC to 4.5 with about 1.47v ish
8GB DDR3 1866 RAM
PowerColor R9 390 8gb
Hi, so all other games like Tomb Raider 2013, BF4, and couple of some minor games run full solid 60FPS with no issue or no drastic frame drops. I think the lowest i ever hit was probably like 54FPS with settings on high with the two games i just mentioned.
HOWEVER with GTA 5 its another story. It runs at 60 fps on certain parts of the map, but when i start driving fast just due over time i start getting low fps, it sometime dips low from 41 to 39 fps. My Gpu should be more the capable to run GTA 5. Prior to this 390 gpu, i had a 960gtx card, and that card ran GTA 5 pretty smooth with almost everything set on high (not ultra).
I moved from Ultra to High with my r9 390 card for GTA 5 and i am still getting some frame rate issues. I did an update for GTA 5 and i got the latest GPU driver Crimson-Edition-16.1 which came out this month of the 7th.
I thought my CPU was holding my GPU back, but from all the forms that i read, and the research that i did, my CPU shouldn't be the issue. I overclocked my CPU to be on the safe side. But still getting framerate issues only for GTA 5 so far. I would install more games to test out my GPU but so far i only tested it out BF4 and TombRaider with pretty much everything set on ultra, and i get no frame rate issues what so ever for those games.
Granted GTA 5 is a newer game between those two games that i just mentioned, but GTA 5 recommended GPU card is 660 GTX, and my card is wayyy more powerful then that. So i am just trying to understand what the issue is here, and if anyone else have faced this problem?
8GB DDR3 1866 RAM
