- Sep 27, 2010
- Spokane Valley, Wa
Yes, that issue has cropped up before. Suggested fix is to manually power off your monitor and set the windows to leave the monitor on all the time.
2 of my secondary machines do something similar to that with the older 6.23 client and windows 7, if I'm also running a cpu client that is, they just won't start a new project after sending results. I have to shut the client down and restart it then it's good to go. Not running a cpu client allows them to work fine also. I have to run the older client as the new F@H says my 2 machines with GTX 260 Core 216s aren't Fermi devices and the other machine with a 1GB 9600 GT fails every work unit, on the older version they are fine.
