Case: Raidmax Hyperion https://www.google.com/search?q=rai...X&ved=0ahUKEwjipdyF6uzLAhVF8CYKHfDPCKQQsAQIJQ
Mild OC on AIO water cooled 6600k, and RAM. No GPU. Maybe a gpu down the road, and if need be, deal with other cooling options if/when that time comes.
For now, I'd like to go with redux throughout, unless someone has a better suggestion for a slightly pressurized flow while keeping it as quiet as possible. If at all, with 7 fans.
http://noctua.at/en/products/fan/redux
Would P14 - 1500 PWM be the replacement for this stock rad fan?
What about the CFM and static pressure differences?
http://noctua.at/en/nf-p14s-redux-1500-pwm
http://www.swiftech.com/Helix140-PWM.aspx
With 2x 140mm on top (one is rad) + 1x 120 rear all being exhaust,
and 4x120 intake (front/bottom),
what other 1x 140mm and 5x 120mm's would I get?
I won't need all the fans to keep it cool, I just don't want to see empty case fan grills in the main compartment.
How would I keep it relatively equalized with pressure? Perhaps 1 or 2 front 120 as PWM?
Using Fan Expert 3 ok?
Thinking these fans, when not used as PWM, can be set to much slower speeds, I'll just throw this out here and see what sticks:
Top 2x 140
P14s 1500 PWM = replacement for the rad Helix, and
P14s 1200 3pin to go next to it. Can't do push/pull.
Rear/front/bottom
NF-S12B -1200 3pin (5) 120's.
Or for the case fans there's 140mm - 900 rpm & 120mm - 700 rpm variants that are quieter, if that's enough air.
Would P14
Top 2x 140
Rear/front/bottom
